Ignition Backup Gateway, Out Of Date Sync issue
Hi There,
The Ignition version we are using is V 8.1.14
Master Sync status : Good
Backup Sync status : Out Of Date
  1. Force Re-Sync both from Master and Backup gateway, no change
  2. move the config.idb file and restarted the backup gateway, no change
PROD 1 log:
|InternalDb|07Sep2023 12:38:18|Error sending system backup to other gateway.|
|com.inductiveautomation.metro.api.ex.RemoteException: Exception occurred on remote machine, message id='4895', error code=GENERAL_PROTOCOL_EXCEPTION [100]
at com.inductiveautomation.metro.impl.protocol.handler.AckErrorHandler.handleMessage(AckErrorHandler.java:76)
at com.inductiveautomation.metro.impl.protocol.websocket.MetroWebSocket.onMessage(MetroWebSocket.java:366)
at jdk.internal.reflect.GeneratedMethodAccessor20.invoke(Unknown Source)
at org.eclipse.jetty.websocket.common.events.annotated.CallableMethod.call(CallableMethod.java:70)
at org.eclipse.jetty.websocket.common.events.annotated.OptionalSessionCallableMethod.call(OptionalSessionCallableMethod.java:72)
at org.eclipse.jetty.websocket.common.events.JettyAnnotatedEventDriver.lambda$onBinaryFrame$0(JettyAnnotatedEventDriver.java:113)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
at java.base/java.lang.Thread.run(Unknown Source)|
PROD 2 log:
|WebSocketConnection|07Sep2023 12:38:18|-> outgoing local='XXXprd01ignt_AAAXXXvlping01-backup' remote='XXXprd01ignt_AAAXXXvlping01-master' method=Metro-RunDownloadThread: Exception occurred in the local system, message id='4895'|
|java.io.FileNotFoundException: /tmp/metro/8317a818-ca23-4b51-aa9c-1df38592868e___statetransfer.gwbk (Permission denied)
at java.base/java.io.FileOutputStream.open0(Native Method)
at java.base/java.io.FileOutputStream.open(Unknown Source)
at java.base/java.io.FileOutputStream.(Unknown Source)
at com.inductiveautomation.metro.impl.codecs.FileStreamCodec.decode(FileStreamCodec.java:143)
at com.inductiveautomation.metro.impl.CentralManagerImpl.handleLocal(CentralManagerImpl.java:429)
at com.inductiveautomation.metro.impl.ConnectionWatcher.handle(ConnectionWatcher.java:429)
at com.inductiveautomation.metro.impl.ConnectionWatcher.handle(ConnectionWatcher.java:44)
at com.inductiveautomation.metro.impl.protocol.websocket.WebSocketConnection.forward(WebSocketConnection.java:1357)
at com.inductiveautomation.metro.impl.protocol.websocket.WebSocketConnection$RunDownload.run(WebSocketConnection.java:1926)
|Intent|07Sep2023 12:38:18|Unhandled Intent failure.|
PROD 1 status log image.
PROD 2 status log image.
Permission denied suggests something is wrong with the backup gateway's folder permissions. Consider deactivating it, uninstalling, re-installing (making sure you get just the matching modules), and configuring its backup role again (so it will try to resync).
Or, perhaps, the disk is full.
Thank you for the comments.
The disk is not full.
When you say de-activate, do you mean to make the master independent and then reinstall the backup?
Thanks in advance.
No, I meant move the license back to IA's license servers so you can completely wipe the install folders (otherwise you'd lose the license).
My spidey sense is firing related to your /tmp folder. What OS are you running? If you run findmnt, are there any special mount configurations for /tmp? I'm remembering some situations where some hardening efforts on /tmp can cause compatibility problems (in which case you can configure a temp folder in Ignition and direct it to use that versus the system-default temp location).
The Ignition is installed on a Linux server.
Thank you for the reply, but I did not understand the suggested method.
I probably should have been more specific to ask what flavor of Linux OS that you're running? Ubuntu? RHEL? Ultimately taking a look at the permissions and mount configuration of /tmp (as Phil suggested) will probably be enlightening.
The system is Linux 7.
While executing the findmnt, we found below results. Could you please help with next step.
Never heard of this. Do you mean RHEL 7 ? (If so, I must say it is really old and troublesome.)
Sorry for the confusion.
I have no knowledge on Linux, from one of the playbook I found something like this, Red Hat Enterprise Linux 7 & OpenJDK8. Not sure whether this makes sense to the team's question.
Now, I believe the answer is RHEL 7 ( Red Hat Enterprise Linux 7).
It does look like perhaps you've got some extra hardening on that system. At this point, I'd probably direct Ignition to use a tmp folder under its own installation folder (instead of the global tmp folder at /tmp) for better compatibility. It might be worth touching base with Support for this.
Thank you for the support, I have raised a support ticket and pasted this link to it.
Will update over here once the solution has been found.
Status issue resolved by providing necessary permission to “/tmp/metro” folder in the backup server.
Thank you all for the support.
