Does anyone know where the .Ignition cache is located when using a Thin Client to run an Ignition client?
The application on the Thin Client has become corrupted after a Gateway restore and I cannot locate where the cache folder is located. I assume it has to be on the server the Thin Client has connected to. There is no local IT support for this customer.
[quote=“Curlyandshemp”]Does anyone know where the .Ignition cache is located when using a Thin Client to run an Ignition client?
Thanks[/quote]
Answered my own question. You have to be logged on as an administrator.
