Hi Team,
Is there any auto logout feature or any code available to prevent application from shutdown accidently due to power failure or if user close application directly .
We tried with client side shutdown-intercept event for handling this but not working.
Our purpose is ,If application closed accidently then we need application to be shutdown in a proper way as per our script.
Thank you,
Sagar
You can remove client exit options in Project Properties, and Client Event Scripts->MenuBar. The shutdown-intercept event cannot be used if the client is force closed like ctrl + alt + delete, or power loss. You could add a UPS (uninterruptable power supply) to the hardware running the client to help prevent power loss events. Depending on the nature of a safe shutdown sequence, you should consider writing a gateway timer script to check for the client status via system.util.getSessionInfo then execute some logic when the client session is ended.
