Ignition Cloud Edition on Azure - Getting Started
I am probably missing something obvious, but will ask to avoid spinning my wheels.
I created and started an instance of Ignition Cloud on Azure. It started fine but the gateway web server does not respond on the assigned public IP address. I can access the bash shell via Azure cloud SSH and confirmed that the Ignition gateway process is running.
What is the next step to get to the Gateway web page so I can configure the system?
Thanks!
I'm pretty sure you have to route through a private lan at first, so you can set up encryption on the new server. When I watched the "getting started" video on IA's channel, Kevin kinda hand-waved that part.
Yeah, I had success with a peer Windows VM on the same private network.
Thanks for the suggestion, Phil!
