Ignition cloud - Gateway Command-line Utility?
Hi All
I have mistakenly renamed the default user source and now I cannot log in. Ignition is hosted on AWS
Is there an option for Ignition Cloud to reset the admin password like gwcmd?
Cheers
You can SSH into the node and invoke gwcmd.sh like a normal Linux installation of Ignition. You can also use EC2 Instance Connect in many cases as well (where you might understandably not have SSH opened in your security group configuration).
Thanks for the information. We ended up restoring the EC2 instance. Luckily this happened just after spinning up.
