Ignition.conf Java Additional Parameters recommendations
Hello community.
Yesterday I tried to upgrade one of the Gateways I maintain from 8.1.28 to 8.1.35 but the Ignition Service failed to start. After looking at the logs it was clear that a Java Additional Parameter inherited from previous versions was the culprit.
I started looking at all of our Gateways' ignition.conf settings and found big differences between them, so I come to ask for recommendations.
Example 1:
# Java Additional Parameters
wrapper.java.additional.1=-Ddata.dir=data
#wrapper.java.additional.2=-Xdebug
#wrapper.java.additional.3=-Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=*:8000
Example 2:
#wrapper.java.additional.1=-XX:PermSize=64m
#wrapper.java.additional.2=-XX:MaxPermSize=128m
wrapper.java.additional.3=-XX:+UseConcMarkSweepGC
#wrapper.java.additional.4=-XX:+CMSClassUnloadingEnabled
#wrapper.java.additional.5=-XX:+CMSPermGenSweepingEnabled
wrapper.java.additional.6=-Ddata.dir=data
wrapper.java.additional.7=-Dorg.apache.catalina.loader.WebappClassLoader.ENABLE_CLEAR_REFERENCES=false
#wrapper.java.additional.8=-Xdebug
#wrapper.java.additional.9=-Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=8000
Example 3:
wrapper.java.additional.1=-XX:+UseConcMarkSweepGC
#wrapper.java.additional.2=-XX:+CMSClassUnloadingEnabled
wrapper.java.additional.3=-Ddata.dir=data
wrapper.java.additional.4=-Dorg.apache.catalina.loader.WebappClassLoader.ENABLE_CLEAR_REFERENCES=false
#wrapper.java.additional.5=-Xdebug
#wrapper.java.additional.6=-Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=8000
wrapper.java.additional.7=-Dedition=
In the docs I could only find a suggestion on how to modify Java Additional Parameters.
Would it be possible to make the installer "smart" enough to remove or flag problematic settings?
E.g., UseConcMarkSweepGC inherited from Ignition 7.
Apparently one can only have -Ddata.dir=data as the only additional parameter, but I am wondering if there are any recommendations from IA.
Thanks.
Look at whatever a fresh install Ignition of 8.1.x does, and do that.
Here's one taken from the docs.
Add parameters like this:
wrapper.java.additional. 1 = - Ddata. dir = data
wrapper.java.additional. 2 = - some.thing = foo
wrapper.java.additional. 3 = - some.other.thing = bar
Avoid skipping commented numbers:
wrapper.java.additional. 4 = - some.thing = foo
8.1.35's fresh ignition.conf looks like this:
wrapper.java.additional.2=--add-opens=java.base/java.lang=ALL-UNNAMED
wrapper.java.additional.3=--add-opens=java.base/java.io=ALL-UNNAMED
wrapper.java.additional.4=--add-opens=java.base/java.security.cert=ALL-UNNAMED
wrapper.java.additional.5=--add-opens=java.base/java.util=ALL-UNNAMED
wrapper.java.additional.6=--add-opens=java.base/jdk.internal.misc=ALL-UNNAMED
#wrapper.java.additional.6=-Xdebug
#wrapper.java.additional.7=-Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=*:8000
There must be some kind of upgrade logic in the installer, because those params became necessary starting with 8.1.33 when we upgraded to JDK 17.
I wouldn't be surprised if it can't handle all the permutations of all the old or custom parameters it might encounter.
You certainly don't need these any more in Ignition 8:
  • -XX:+UseConcMarkSweepGC
  • -Dorg.apache.catalina.loader.WebappClassLoader.ENABLE_CLEAR_REFERENCES=false
or anything that's commented out, really.
