Hi I am after some guidance hopefully, have a network with an S7-300 PLC with and S7-1200 polling it for data. I want to connect the S7-300 to ignition, this is where I am seeing the issue, Ignition will connect to the S7-1200 but not the 300.
If i disconnect the S7-1200 PLC from the network ignition will connect straight to the S7-300 with no problems, has anyone come across this, I do not seem to be able to find any settings in Siemens hardware configuration and I am a bit at scratching my head now, I have changed the resourcing levels to accept a different number of connections but this hasn’t helped.
Anything to try would be good?
Regards
Chris
