Hello Ignition Support,
I’m investigating the possibility of deploying Ignition in a FIPS-certified environment. FIPS prohibits the use of certain cryptography algorithms, and it looks like Ignition by default may rely on one or more of these prohibited algorithms.
I have a server running RHEL 9.6 for aarch64 in FIPS mode. I’m attempting to deploy Ignition 8.3.0 for arm64. The installation succeeds, however, when I run ignition.sh start I get a message that the gateway may not have started properly. wrapper.log shows the following stack trace:
INFO | jvm 1 | 2025/10/02 15:35:18 | E [g.CompositeClassRejectListFilter] [15:35:18.905]: Error initializing secure random.
INFO | jvm 1 | 2025/10/02 15:35:18 | java.security.NoSuchAlgorithmException: SHA1PRNG SecureRandom not available
INFO | jvm 1 | 2025/10/02 15:35:18 | at java.base/sun.security.jca.GetInstance.getInstance(GetInstance.java:159)
INFO | jvm 1 | 2025/10/02 15:35:18 | at java.base/java.security.SecureRandom.getInstance(SecureRandom.java:387)
INFO | jvm 1 | 2025/10/02 15:35:18 | at com.inductiveautomation.ignition.common.util.SecureRandomProvider.<init>(SecureRandomProvider.java:45)
INFO | jvm 1 | 2025/10/02 15:35:18 | at com.inductiveautomation.ignition.common.util.SecureRandomProvider.initialize(SecureRandomProvider.java:27)
INFO | jvm 1 | 2025/10/02 15:35:18 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.<init>(IgnitionGateway.java:560)
INFO | jvm 1 | 2025/10/02 15:35:18 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.main(IgnitionGateway.java:307)
INFO | jvm 1 | 2025/10/02 15:35:18 | at com.inductiveautomation.catapult.Catapult.main(Catapult.java:8)
INFO | jvm 1 | 2025/10/02 15:35:18 | at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2025/10/02 15:35:18 | at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
INFO | jvm 1 | 2025/10/02 15:35:18 | at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
INFO | jvm 1 | 2025/10/02 15:35:18 | at java.base/java.lang.reflect.Method.invoke(Method.java:569)
INFO | jvm 1 | 2025/10/02 15:35:18 | at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:349)
INFO | jvm 1 | 2025/10/02 15:35:18 | at java.base/java.lang.Thread.run(Thread.java:840)
It looks like Ignition is using SHA1, which is not available in FIPS environments.
Is there any way for users to specify or supply cryptography algorithms for Ignition to use? Can you point me in the right direction?
Thank you!
