I have configured a database connection to the SQL database for historical data logging. Even though, there is 20 connections available in the pool for this connection, i notice that only one connection is used at any time. However, the local cache keeps filling up. Yesterday it was 30% full and now it around 70% full. Even though connections to the database are available, Store and forward component is not using it. How to force Store/forward component using multiple connections from the pool and clear the cache
Could be a bug. Could be a limitation in the JDBC driver. Could be a configuration mistake. You haven’t provided nearly enough information to tell. So:
- What DB brand and version?
- What JDBC driver version?
- What Ignition version?
- Are there errors in the wrapper log that look relevant?
- Can you show us the connection pool settings?
If urgent, consider opening a support ticket and having them look over your shoulder.
