Ignition Dedicated IP Address?
Hi Jordan,
Thanks for the response. Sorry my terminology is fuzzy.
We need to make a permanent connection between our MySQL database that is on a server (HostGator) to our Ignition server. We need the connection between the two servers to stay valid even when no PCs are connected.
Maybe my understanding of how Ignition works is incorrect. My understanding is that PCs are used to program the back-end of the Ignition server using Ignition Designer. All of the processing takes place on an Ignition server.
1.) Does Ignition need to have a PC connected at all times in order to operate?
If not then I need to give the Ignition server permission rights to our HostGator server.
2.) Does each account with Ignition have a dedicated, static IP address?
I’m trying use static IP addresses.
3.) Where can I find the static IP address of my Ignition server.
Hopefully that answers your questions. If you have any more please let me know, I appreciate the help!
