Ignition Deleting Tag History
At some point, tag history tables were deleted manually (due to memory) from our SQL database. Pruning was then set up on a monthly basis. However, in the gateway logs, errors continue to populate with the following error message:
I believe deleting the corresponding row from the sqlth_partitions table will remove these error messages from occuring.
Does anyone know if doing so will cause any problems? Thanks
Might want to check the sqlth_partitions table and remove the partitions you've deleted.
