I have installed the Ignition Demo 08_19_2012 onto a debian 6 test server.
I manually created the “demo” and “mes” databases in MySQL, and the database connections are shown as OK.
The Ignition demo and Mobile Project work. The OEE/DT/Schedule Demonstration & Quality Demo do not work.
The Status page (Image Attached) shows an error on the Device and OPC connections.
Any tips on how to resolve this
java.lang.Exception: OPC server connection is faulted. Type "Production_ServerType" is not a known server type.
com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl.create(OPCManagerImpl.java:171)
com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl.addAllServers(OPCManagerImpl.java:140)
com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl.startup(OPCManagerImpl.java:91)
com.inductiveautomation.ignition.gateway.SRContext.startupInternal(SRContext.java:975)
com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:184)
com.inductiveautomation.ignition.gateway.SRContext.asyncInit(SRContext.java:766)
com.inductiveautomation.ignition.gateway.SRContext.access$200(SRContext.java:191)
com.inductiveautomation.ignition.gateway.SRContext$2.run(SRContext.java:557)
com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:526)
java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
java.util.concurrent.FutureTask.run(FutureTask.java:138)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:98)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:206)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
java.lang.Thread.run(Thread.java:662)
