I am not able to login to Ignition designer…? My user name & password every thing is corrrect. What may be the reason?? Even I could see the status & configure page with the same user name and password.
Can you check that the designer role is correct? In the gateway config page under the gateway you can specify which authentication profile and which roles have access to what.
