Ignition Designer Not Saving Changes
Hello,
Our ignition designer is not saving changes to our Prospective project. We attempt to create a new perspective view and when we attempt to save and reopen the project the changes are reverted. PLEASE HELP.
I have uploaded a screenshot and a copy of the console
error.txt (33.3 KB)
  • Jonathan
A NoSuchMethodError indicates something is fundamentally broken in the Java files available to the local runtime.
The most likely cause of this, from experience, is a flawed ZIP "install".
You should first check that your module's versions agree with the platform. If they do, then you will need to take a gateway backup, uninstall cleanly, then reinstall and restore your backup.
Or, you can contact support, and they can get a live look at your system and get a better idea of what might have gone wrong.
Thank you, I have completed the clean reinstall and so far no issues.
