Ignition Designer Perspective "ERR_CERT_AUTHORITY_INVALID"
If anyone could help, I would greatly appreciate it.
I have installed the cert on the local machine and the designer however I am still greeted with this error when I try to access perspective views on designer. This issue was not present before
The CN and the SAN's on the cert match up with the URL.
If you consider the hostname and certificate sensitive you should probably give support a call. The first thing anybody should be doing is taking a look at your certificate and the URLs in play here.
