Ignition Edge and Ignition Server , I want to fetch Ignition Server Tags on Ignition Edge gateway.
Can you suggest any link or step by step procedure to do this
Pretty sure everything in Edge is designed to go the other way. Have you tried creating a remote tag provider in Edge pointing at your standard gateway? (I'm not sure it is allowed, but that is what you would need.)
Consider replacing Edge with Standard.
Ignition Edge allows only a single tag provider to be configured. You'll need to use an atypical approach, perhaps using message handlers between the two gateways. You could:
In all of the above, verbose documentation on the Edge tags (identifying the source of the data) will be a life-savor to your future colleagues.
Feel free to provide additional details if you'd like a recommendation on a path forward. What kind of tag data is needed? How frequently must this data be synchronized?
