Good morning.
In Ignition Edge 8.1.17, when I enable the option "DataSync -> Settings -> Remote Journal Sync Enabled":
...the Gateway (Edge) reboots repeatedly and I get these errors in the logs:
If I run the command top (linux), the "java" process is consuming a lot of CPU. That's why it restarts.
This server only has Ignition Edge installed.
Also, all tags on all devices have "uncertain" quality:
Best Regards.
