Ignition Edge Data Base Licensee
Hi Folks,
I am using the Ignition edge. for my current Project.
Is it possible to have the Data Base or Tag Histrion over there.
In case we need to buy the Module,
1.) What is the Name of module
2.) How can we connect the Data Base.?
3.) what are data bases where module supported?
4.) what might be the Pricing Coast on that Module?
5) If we can be able to access what might be the Limitations of the Module?
Let me Know the Possibilities for the above-Mentioned Query through overcome this. we are eagerly waiting for the Response. Though we can start Implement.
Adarsh, :wave:
No, not possible on Edge. Use the full version if you need DB.
HI @Matrix_Engineering
Whether it's possible through the Module or external module to use them .
Not possible at all on Edge.
And external modules are not allowed on Edge. (Only Cirrus Link and IA's own modules are allowed.)
No longer limited to Cirrus Link, with vetting. Back doors enabling DB access are precisely the kinds of things that won't get approved.
