I have Ignition Edge installed on the plant, and Ignition Gateway on the cloud.
From the Ignition Edge we can ping the Ignition Gateway, and Diagnostic at Gateway Network setting on Ignition Gateway also show successfully connection.
However Data synchronization always shows error:
HistorianSyncable - Error Synchronizing Data
java.util.concurrent.ExecutionException: TimeoutExpiredException[queueId=default, targetIntent=th_storage, msgData=systemId: “Edge144” providerId: “edge” tags { tagPath: “[edge]SPINDO/OPCUA/Recorder/LogData/D7056” mode: ANALOG type: Float8 timesrc: VALUE } tags { tagPath: “[edge]SPINDO/OPCUA/Recorder/LogData/D7057” mode: ANALOG type: Float8 timesrc: VALUE } tags { tagPath: “[edge]SPINDO/OPCUA/Recorder/LogData/D7028” mode: ANALOG type: Float8 timesrc: VALUE } tags { tagPath: “[edge]SPINDO/OPCUA/Recorder/LogDrv/D7113” mode: ANALOG type: Float8 timesrc: VALUE } tags { tagPath: “[edge]SPINDO/OPCUA/Recorder/LogData/D7029” mode: ANALOG type: Float8 timesrc: VALUE } tags { tagPath: “[edge]SPINDO/OPCUA/Recorder/LogDrv/D7105” mode: ANALOG type: Float8 timesrc: VALUE } tags { tagPath: “[edge]SPINDO/OPCUA/Recorder/LogDrv/D7138” mode: ANALOG type: Float8 timesrc: VALUE } tags { tagPath: “[edge]SPINDO/OPCUA/Recorder/LogDrv/D7126” mode: ANALOG type: Float8 timesrc: VALUE } tags { tagPath: “[edge]SPINDO/OPCUA/Recorder/LogDrv/D7107” mode: ANALOG type: Float8 timesrc: VALUE } tags { tagPath: “[edge]SPINDO/OPCUA/Recorder/LogDrv/D7128” mode: ANALOG type: Float8 timesrc: VALUE } tags { tagPath: “[edge]SPINDO/OPCUA/Recorder/LogDrv/D7161” mode: ANALOG type: Float8 timesrc: VALUE } tags { tagPath: “[edge]SPINDO/OPCUA/Recorder/LogDrv/D7140” mode: ANALOG type: Float8 timesrc: VALUE } tags { tagPath: “[edge]SPINDO/OPCUA/Recorder/LogDrv/D7101” mode: ANALOG type: Float8 timesrc: VALUE } tags { tagPath: “[edge]SPINDO/OPCUA/Recorder/LogDrv/D7155” mode: ANALOG type: Float8 timesrc: VALUE } values { key: 0 value { values { tstamp: 1658137302110 quality: 192 dval: 270.0 } } } values { key: 1 value { values { tstamp: 1658137303110 quality: 192 dval: 269.0 } } } values { key: 2 value { values { tstamp: 1658137304109 quality: 192 dval: 402.3 } } } values { key: 3 value { values { tstamp: 1658137304118 quality: 192 dval: 15.2 } } } values { key: 4 value { values { tstamp: 1658137304109 quality: 192 dval: 50.1 } } } values { key: 5 value { values { tstamp: 1658137305118 quality: 192 dval: 14.6 } } } values { key: 6 value { values { tstamp: 1658137305118 quality: 192 dval: 14.2 } } } values { key: 7 value { values { tstamp: 1658137304118 quality: 192 dval: 14.2 } } } values { key: 8 value { values { tstamp: 1658137304118 quality: 192 dval: 15.4 } } } values { key: 9 value { values { tstamp: 1658137305118 quality: 192 dval: 16.3 } } } values { key: 10 value { values { tstamp: 1658137305118 quality: 192 dval: 14.9 } } } values { key: 11 value { values { tstamp: 1658137304118 quality: 192 dval: 15.3 } } } values { key: 12 value { values { tstamp: 1658137302116 quality: 192 dval: 13.7 } } } values { key: 13 value { values { tstamp: 1658137302116 quality: 192 dval: 14.3 } } } targetHistorian: “MariaDB” ]
at java.base/java.util.concurrent.CompletableFuture.reportGet(Unknown Source) …
Any idea how to solve this ?
