Ignition Edge limitation
I recall originally edge have a 500 tag count limitation that was later removed. Is there a maximum recommended tag count that ignition recommends user adhere to? I recognize that the variability of edge devices makes this use case dependent.
The reason I ask, running edge in an Opto 22 device, No issues when the tag count was < 1000. As we creeped up 2-3K and added perspective sessions, we started to see CPU utilization increase and occasional GAN errors. Simply disabling half the tags would remove the issue. Ended up disabling edge and going OPC directly from server to device, no more issues.
This is more llkely the culprit than a few extra tags. Perspective is a CPU hog. See this discussion:
(Read the whole topic.)
