Ignition Edge Limitations
Hello,
What limitations does Ignition Edge have with a licence?
Does it have device connections and tag limits?
Does it limit the number of perspective sessions?
Many Thanks
2 devices, no tag limits
1 local session 1 remote session
It depends on the licensed edition as well as any modifications you may have negotiated when buying it… it’s gotten a bit complicated to accommodate a range of use cases. It’s probably best to talk to a sales person about what you might need from it.
So it is possible to buy Ignition Edge without the two device connection limit?
Yes, it’s possible. I don’t know if that’s an edition thing or just a custom detail you can negotiate.
It’s $100 per extra device beyond the standard two, so you quickly reach a point where full-fledged Ignition makes more sense
There’s a single page in the user manual that does a pretty good job capturing all the differences / limitations.
Ignition 8.1: Ignition Edge - Ignition User Manual 8.1 - Ignition Documentation
(Ignition 8.0: Ignition Edge - Ignition User Manual 8.0 - Ignition Documentation )
