Hi, I am having an issue launching the ignition edge software on my gateway. The installation was successful however, when trying to run, I receive a message that ignition is now running but the PID is not present in the list of running processes. It seems like it is closing immediately. The console says that it is running into an error:
jvm 1 | WrapperSimpleApp:
jvm 1 | WrapperSimpleApp Error: Encountered an error running main:
jvm 1 | WrapperSimpleApp Error: java.io.EOFException
jvm 1 | WrapperSimpleApp Error: at java.io.DataInputStream.readInt(DataInputStream.java:392)
jvm 1 | WrapperSimpleApp Error: at sun.security.provider.JavaKeyStore.engineLoad(JavaKeyStore.java:653)
jvm 1 | WrapperSimpleApp Error: at sun.security.provider.JavaKeyStore$JKS.engineLoad(JavaKeyStore.java:56)
jvm 1 | WrapperSimpleApp Error: at sun.security.provider.KeyStoreDelegator.engineLoad(KeyStoreDelegator.java:224)
jvm 1 | WrapperSimpleApp Error: at sun.security.provider.JavaKeyStore$DualFormatJKS.engineLoad(JavaKeyStore.java:70)
jvm 1 | WrapperSimpleApp Error: at java.security.KeyStore.load(KeyStore.java:1445)
jvm 1 | WrapperSimpleApp Error: at org.eclipse.jetty.util.security.CertificateUtils.getKeyStore(CertificateUtils.java:52)
jvm 1 | WrapperSimpleApp Error: at org.eclipse.jetty.util.ssl.SslContextFactory.loadKeyStore(SslContextFactory.java:1016)
jvm 1 | WrapperSimpleApp Error: at org.eclipse.jetty.util.ssl.SslContextFactory.doStart(SslContextFactory.java:332)
jvm 1 | WrapperSimpleApp Error: at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
jvm 1 | WrapperSimpleApp Error: at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:132)
jvm 1 | WrapperSimpleApp Error: at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:114)
jvm 1 | WrapperSimpleApp Error: at org.eclipse.jetty.server.SslConnectionFactory.doStart(SslConnectionFactory.java:64)
jvm 1 | WrapperSimpleApp Error: at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:260)
jvm 1 | WrapperSimpleApp Error: at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:81)
jvm 1 | WrapperSimpleApp Error: at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:244)
jvm 1 | WrapperSimpleApp Error: at org.eclipse.jetty.server.Server.doStart(Server.java:384)
jvm 1 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.Jetpad.start(Jetpad.java:323)
jvm 1 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.Catapult.start(Catapult.java:135)
jvm 1 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.Catapult.main(Catapult.java:62)
jvm 1 | WrapperSimpleApp Error: at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
jvm 1 | WrapperSimpleApp Error: at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
jvm 1 | WrapperSimpleApp Error: at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
jvm 1 | WrapperSimpleApp Error: at java.lang.reflect.Method.invoke(Method.java:498)
jvm 1 | WrapperSimpleApp Error: at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:325)
jvm 1 | WrapperSimpleApp Error: at java.lang.Thread.run(Thread.java:748)
jvm 1 | I [g.ModuleManager ] [09:17:05]: Loading modules…
I am not aware of any issues that may be causing this problem and I have tried resetting, uninstalling and reinstalling the software to no avail.
Thank you in advance
