We have a customer asking to run Ignition Edge on a Beckhoff IPC. The Beckhoff IPC runs Windows10 so I think I should be able to install it on there? Could it be as simple as installing Ignition on the IPC and having the Beckhoff tags exposed to OPC?
Thanks,
Chuck
Yep ![]()
Think maybe @ASF uses beckhoff IPC’s already
Yes, we’ve done this with full Ignition + Vision client. Configure TwinCAT OPC-UA and connect to it from Ignition.
Sorry, not me - sounds like a neat solution though!
