Every once in a while (maybe once or twice a month) my version of Ignition Edge (8.1.14) will experience a fault with the default “Ignition OPC UA Server”. The server will continuously loop between “Connecting” and “FAULTED”.
Below I’ve pasted the error message I get from the server monitoring page:
UaException: status=Bad_Timeout, message=timed out waiting for secure channel
at org.eclipse.milo.opcua.stack.client.transport.uasc.UascClientMessageHandler.lambda$handlerAdded$2(UascClientMessageHandler.java:135)
at io.netty.util.HashedWheelTimer$HashedWheelTimeout.expire(HashedWheelTimer.java:672)
at io.netty.util.HashedWheelTimer$HashedWheelBucket.expireTimeouts(HashedWheelTimer.java:747)
at io.netty.util.HashedWheelTimer$Worker.run(HashedWheelTimer.java:472)
And below I’ve put what I believe are relevant snippets from the error logs (screenshots + content):
and
java.lang.OutOfMemoryError: Direct buffer memory
at java.base/java.nio.Bits.reserveMemory(Unknown Source)
at java.base/java.nio.DirectByteBuffer.(Unknown Source)
at java.base/java.nio.ByteBuffer.allocateDirect(Unknown Source)
at io.netty.buffer.PoolArena$DirectArena.allocateDirect(PoolArena.java:645)
at io.netty.buffer.PoolArena$DirectArena.newChunk(PoolArena.java:621)
at io.netty.buffer.PoolArena.allocateNormal(PoolArena.java:204)
at io.netty.buffer.PoolArena.tcacheAllocateSmall(PoolArena.java:174)
at io.netty.buffer.PoolArena.allocate(PoolArena.java:136)
at io.netty.buffer.PoolArena.allocate(PoolArena.java:128)
at io.netty.buffer.PooledByteBufAllocator.newDirectBuffer(PooledByteBufAllocator.java:378)
at io.netty.buffer.AbstractByteBufAllocator.directBuffer(AbstractByteBufAllocator.java:187)
at io.netty.buffer.AbstractByteBufAllocator.directBuffer(AbstractByteBufAllocator.java:178)
at io.netty.buffer.AbstractByteBufAllocator.ioBuffer(AbstractByteBufAllocator.java:139)
at io.netty.channel.DefaultMaxMessagesRecvByteBufAllocator$MaxMessageHandle.allocate(DefaultMaxMessagesRecvByteBufAllocator.java:114)
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:150)
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:719)
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:655)
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:581)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:493)
at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:989)
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74)
This is on a trial version of Ignition Edge, but otherwise Ignition Edge seems to be functioning with no issues. The only solution seems to be restarting the server. Obviously the internal OPC UA server faulting is a pretty big deal though. Is this normal behavior?
