I am new to Ignition and have never used it before (used some other packages in the past, such as InTouch / Citect), but looking currently for a small, modern HMI package for a control panel.
It should be a standalone (non-redundant) device running on an embedded Windows PC fitted in the panel.
I will need the following functionality:
- two slave devices (flow computers) talking Modbus TCP,
- a number of displays for process data, calculated values, totalizers, etc.,
- a couple of trend displays.
From what I have seen, Ignition Edge should suffice in this instance.
However, I may also need the following functionality on top:
- PDF reporting (hourly / daily reports to be generated with totalizer values and averages, etc.),
- Modbus TCP or Modbus RTU handoff to an external system, so the Ignition package should act as a Modbus slave.
Does it mean I would need to go for the full-blown Ignition with custom modules, i.e. the Reporting module and 3rd party Modbus module (to support slave functionality)?
