Hello,
This is the first time have used Ignition. I have installed Ignition Edge (Trial Mode) on a Ubuntu Server. I want to setup the device simulator and create some Persepective pages. I can access the gateway and and can see the trial mode is running.
I have noticed under System/Ignition Edge Products & Modules tab under Not Installed, Ignition Edge Panel has expired. Under the Installed I have Ignition Edge Compute, Ignition Edge IIoT and Ignition Edge Sync Service are all in trial mode. See screen shot below.
I have read that you need to enable the Visualization Module under the Edge Settings. I have done this and restarted the server. this has not resolved the issue.
How do I get Ignition Edge Panel installed and working in Trial mode.
thank for your help.
I'm thinking the module didn't get installed during the setup phase, specifically the Vision Module. How does the module health page look, as in how many are installed onto the system? When this was installed, were all modules selected, only a certain amount, or was it default? Reinstalling and selecting all modules should alleviate this issue or you can install it manually from our website. Please be sure to select the version that corresponds with the system.
I did the default install on ubuntu there was no options (that I am aware of) to install different modules.
Manually installed the Perspective module and that came up with a trial license and status of active. This did not resolve the issue.
Manually installed the Vision module and that came up with a trial license and status of active. I now have Ignition Edge Panel Installed.
cheers
