Ignition Edge Panel - Export Trend Data
With Ignition Edge Panel - specifically running a Perspective session - is there anyway to export the 1 week of historical data from a trend to a csv file? Apologies if this is in the docs but I can’t seem to find it.
Thanks in advance!
If you’re using the Power Chart it has an “Export” option under the 3 dots button. Not sure if that helps in your situation…
Thanks. I guess one could assume that however the data gets into that object that the functionality will work.
