I have a Raspberry Pi 3 B+ that I was hoping to run Ignition Edge Panel + MQTT on. I’ve got it installed and running, but it seems to bring the system to a crawl. My hope was that I could run Node-Red to bridge GPIO to MQTT, and then Edge Panel/MQTT to bring data into Ignition. Any suggestions?
Limit the memory of ignition to 1gb. It defaults to 2gb, which is all rpi 3 memory.
And remove gui for raspberry os, I use the lite image. And never use chromeum browser
I was set to 1024Mb. Is the Pi 3 insufficient to run a browser on top of Edge Panel? Or is Chromium the issue?
