Ignition Edge running on Yocto IoT Edge device
I am working on getting ignition edge running on an edge IoT device with Yocto aarch64 linux environment. I have been able to install and run the application in a docker container. I was told that some of the peripherals of the device must be configured to work properly with the ignition edge software.
My question is, are there certain hardware components that ignition edge utilizes to be able to ingest data, visualize the data, export the data, etc.?
Are there certain network parameters that must be configured to work properly with the ignition edge software, network interface, telemetry, etc.?
if the device has I/O, serial, tcp protocols are there specific things that must be configured either on the device and/or in the ignition software to allow for these hardware to software interactions?
If my questions are not clear please inquire for additional information. Thank you for you time and help.
If it's installed and running, and you can access the Gateway web page, then there's not really anything else left, is there?
Make sure you can make outbound TCP connections with drivers maybe?
