I just wants to know if there any settings in Ignition Edge that we can do so that when we are reading Tags values from OPC systems then it also reads the tags which have no value change but timestamp change.
As when I have tested in my IoT lab , found that Ignition edge did not send those tags value to mqtt transmitter for which no value change even if the timestamp got changed.
We want a settings from Ignition Edge to sends all tag values to the MQTT transmitter after reading Honeywell OPC system which have either value change or timestamp change.
