I am currently working on automating agent installation packages on edge nodes, Automated Agent Installation | Ignition User Manual, and that has been successful so far but these gateways will need the 'Visualization Mode' set to perspective instead of the defaulted Vision, and I am unable to find where this would be in the config file or find what property this would be to address. I have checked here, Gateway Configuration File Reference | Ignition User Manual, but there is no reference of this parameter. Is there a way to default this to perspective on ignition install or am I mistaken about the necessity of this parameter, these nodes will be fully licensed with perspective.
My apologies, the point of this is to automate this process where we can slap a usb in a panel and it will launch edge already configured without having to restore from a backup, as we have numerous panels that will be needing it. I am able to configure the gateway network and agent with two additional files in the data folder but I am not seeing any documentation on the visualization mode and it does not appear to be exposed in the config files anywhere
The config data like that is stored in the internal DB for ignition I think (This goes away in 8.3 I believe) but I don't think there is a good way outside of having a backup. You have to install Ignition and license it anyways/configure it for the GAN.
You may just spend more time thinking about how to achieve this than you would just clicking the dropdown.
