I would like to test the Edge MQTT module and it is nowhere to be found.
I am testing this on a Raspberry Pi 3. It worked for awhile and then locked up. After reboot, I cannot start Ignition. I keep getting the following error in my wrapper:
Thank you for the prompt reply. It was the gateway. We found a version of java 8 before Oracle decided to charge for the license. That fixed the problem. The version of Ignition is 7.8. So we are fixing all the client to have the same version. That should take care of our problems.
