Ignition Editor Bug while writing script
I'm encountering a strange issue in the Ignition Editor. When I select and then deselect text, the lines in the editor seem to shift or change places unexpectedly.
Has anyone else experienced this behavior? Is this a known bug, or is there a workaround that I might be missing?
Thanks in advance for your help!
What ?
Nothing is changing in your example...
Check line 88 last word it's shifting a little bit
Yes, I see that, it's like something goes bold or some kerning changes, but... I don't see how it can cause any loss of productivity.
I saw this and thought I should share it. It was just a suggestion on text editor
I've honestly never noticed this. I'll try to see if I can reproduce, but it's probably going to end up a very low priority bug we file upstream with the code editing library we use.
