Hi Ignition Lovers,
I’m seeing inconsistent SMTP behavior in my Ignition environment and would appreciate your help.
Summary
Gateway “Send Test Email” (Config → Network → Email Settings → my profile) works.
Sending from a script (Script Console) fails with:
com.sun.mail.smtp.SMTPSendFailedException: 530 5.7.0 Must issue a STARTTLS command first -
I need to trigger a Report and email it asynchronously from a button.
Environment
Ignition Gateway: version 8.1.48 on Windows 11
SMTP provider: Gmail
Email Profile name: A
Profile settings currently:
Host:
smtp.gmail.com -
Port: 587
Use STARTTLS: enabled
Use SSL/TLS port: disabled
Require authentication: enabled
Username / From:
xmedxxxc97@gmail.com -
Password: Google App Password
Steps to Reproduce
In Gateway, create/update the Email Profile A with the settings above.
Click Send Test Email → email is delivered successfully.
In Designer, run the simplest send (and also from a button):
system.net.sendEmail( smtp = "smtp.gmail.com", # exact SMTP fromAddr = "xmedxxxc97@gmail.com", # same as profile username to = ["xmedxxxc@gmail.com"], # Another GMAIL account as destinatary subject = "SMTP test", body = "Hi, the email is here" ) -
Result: failure with GatewayException; Java cause:
com.sun.mail.smtp.SMTPSendFailedException: 530-5.7.0 Must issue a STARTTLS command first
(When I trigger a report and attach its bytes, the same error occurs.)
What I’ve Tried
Verified the profile by sending the Gateway test (works).
Ensured the script calls the same profile name (“A”).
Confirmed From == Username and I’m using a Gmail App Password.
Verified basic connectivity to smtp.gmail.com:587/465 from the machine.
Reviewed logs (snippet below).
Log Snippet
Caused by: com.sun.mail.smtp.SMTPSendFailedException: 530-5.7.0 Must issue a STARTTLS command first. ...
at com.sun.mail.smtp.SMTPTransport.sendMessage(SMTPTransport.java:1300)
The error have a poor description of the cause explained for Google here :
https://support.google.com/a/answer/3726730?hl=es&ref_topic=1355150&sjid=8121797102622003986-NA#
Questions
Is there any known issue/limitation where system.net.sendEmail from Client/Designer scope might not honor the STARTTLS/SSL settings of the named Email Profile—even though the Gateway “Send Test Email” does?
Is there a recommended way to guarantee the email is sent in Gateway scope using the same profile (e.g., via
system.util.sendRequestto a Gateway Message Handler) to avoid scope-related differences? -
Any additional logging flags for JavaMail in Ignition to confirm the STARTTLS handshake when called from scripts?
