Ignition Embedded Appliance
Testing Ignition with "Eltechs ExaGear Desktop" emulator on ARM platform:
I am testing Ignition on ARM debian platform with the help of "Eltechs ExaGear Desktop" emulator which enables 32 bit x86 application to run on ARM-based machines.
eltechs.com/product/exagear-desktop/
When i start ignition, i am getting this error message:
root@debian-armhf@x86:/etc/ignition# /etc/init.d/ignition start
Starting Ignition Gateway...
Waiting for Ignition Gateway...........................
WARNING: Ignition Gateway may have failed to start.
Emulation environment before starting exagear:
alam@debian-armhf:~$ uname -a
Linux debian-armhf 3.2.0-4-vexpress #1 SMP Debian 3.2.51-1 armv7l GNU/Linux
This is 32 bit arm-debian
Emulation environment after starting exagear:
Installed successfully "ignition-7.7.1-linux-32-installer.run" with OPC UA and web service modules under Exagear
alam@debian-armhf:~$ sudo exagear
[sudo] password for alam:
Starting the shell in the guest image /opt/exagear/images/ubuntu-1204lts
root@debian-armhf@x86:~# uname -a
Linux debian-armhf 3.2.0-4-vexpress #1 SMP Debian 3.2.51-1 i686 i686 i386 GNU/Linux
This is 32 bit x86-Ubuntu under Exagear 32 bit
root@debian-armhf@x86:~# java -version
java version "1.8.0_25"
Java(TM) SE Runtime Environment (build 1.8.0_25-b17)
Java HotSpot(TM) Client VM (build 25.25-b02, mixed mode)
I have attached the latest wrapper.log and ignition.conf file. Pls check if you can help me to start ignition.
ignition_conf.txt (8.34 KB)
wrapper.log (95.6 KB)
R.Alamsha:
Not exactly what you’re looking for, but… inductiveautomation.com/for … 50&t=13171
