When our users get an error and click on the Report Details to send the error message to us, it’s not saying what window they were in when they got the error. It’s an incredibly verbose report other than that, so is it possible that the name of the window is buried in there somewhere? Here’s one that I manually triggered:
[quote]CD-Key
HKL55N
User
User Name
user.name@domain.com
User Message
dan, testing the error reporting from ignition designer
Error Message
Error executing script for event: actionPerformed
on component: btnSave.
Error Details
File “”, line 49, in
NameError: name ‘errinfo’ is not defined
at org.python.core.Py.NameError(Py.java:260)
at org.python.core.PyFrame.getname(PyFrame.java:257)
at org.python.pycode._pyx7987.f$0(:91)
at org.python.pycode._pyx7987.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:568)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:561)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:170)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:265)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at com.sun.proxy.$Proxy23.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
System Details
fpmi.client.memory.used=1020.50
fpmi.client.memory.max=1820.50
fpmi.client.type=Designer
fpmi.client.version=7.7.1 (b2014092209)
java.vm.version=24.71-b01
java.vm.vendor=Oracle Corporation
java.vm.name=Java HotSpot™ 64-Bit Server VM
user.country=US
os.name=Windows 7
os.arch=amd64
sun.os.patch.level=Service Pack 1
os.version=6.1
java.specification.version=1.7
user.language=en
ignition.gateway.version=7.7.1 (b2014092209)
ignition.gateway.memory.used=990.75
ignition.gateway.memory.max=990.75
ignition.gateway.uptime=2 days, 21 hours, 57 minutes, 6 seconds
ignition.module.com.inductiveautomation.alarm-notification=2.7.1 (b2014092209) - RUNNING
ignition.module.apachecommons=3.2.0 (b1) - LOADED
ignition.module.itext=5.1.3 (b0) - LOADED
ignition.module.math=3.3.0 (b0) - LOADED
ignition.module.mobile=2.7.1 (b2014092209) - RUNNING
ignition.module.xopc=2.7.1 (b2014092209) - RUNNING
ignition.module.poi=3.9.0 (b0) - LOADED
ignition.module.rept=2.7.1 (b2014092209) - LOADED
ignition.module.com.inductiveautomation.sfc=1.7.1-beta11 (b2014092209) - RUNNING
ignition.module.help=2.7.1 (b2014092209) - RUNNING
ignition.module.fpmi=7.7.1 (b2014092209) - RUNNING
ignition.module.com.inductiveautomation.webbrowser=1.7.0 (b2014071518) - LOADED
user.country=US
os.name=Windows 7
os.arch=amd64
os.version=6.1
user.language=en
[/quote]
