Experts!
I need your help in understanding why I can't have multiple cases for one result.
https://docs.inductiveautomation.com/display/DOC81/switch
This documentation shows how I can use the switch statement, so for one of the tag, I'm trying to create an expression tag that looks like this:
switch({[default]RFID_Trial/Department},
{[default]RFID_Trial/Department_list[7,0]} || {[default]RFID_Trial/Department_list[8,0]},
"Engineering",
"Unauthenticated")
Is this just the limitation of the Ignition itself, or am I having a wrong syntax?
Your help is much appreciated, thank you!
That's equivalent to,
If({[default]RFID_Trial/Department} =
"Engineering",. // if true.
"Unauthenticated". // if false
Is this what you really want?
The case syntax is easier to read than switch.
https://docs.inductiveautomation.com/display/DOC81/case
Probably best to use case and this:
case({[default]RFID_Trial/Department},
{[default]RFID_Trial/Department_list[7,0]}, "Engineering",
{[default]RFID_Trial/Department_list[8,0]}, "Engineering",
"Unauthenticated")
Thank you,
But I do want to avoid the use of If-Elseif-else logic in my application for this one, because there's going to be 10 result outcomes I need, with each result having 2-10 conditions for each result.
It could end up getting into a nested ifs also.
On second thought... I think it would still look ugly with case
I'll stick with if statements.
pturmel
October 13, 2023, 11:17pm
6
Just to finish the explanation: "OR" in expressions is either logical or bitwise--it never assembles a list of values for another operator to act upon. (This is true in python, too.)
