Ignition File Brower Default Location
Having an issue with the file browser in ignition (when adding pictures, looking for a file to import, etc) defaulting to a network location that freezes my designer, forcing me to close and reopen. Is there any way I can prevent it from opening to the last location I was in? I mistakenly opened that network folder once and now I can’t navigate anywhere else…
You could try deleting the .prefs and .layout files at the root of the .ignition/ cache folder, which by default is located in your user profile directory (different per OS).
Update: tried deleting the .pref and .layout files which unfortunately did not do the trick. Managed to get it to allow me to flip to a different folder by turning my WiFi off so that the network folder was unavailable. Thanks!
