I’ve had this happen a few times before, just went in, deleted the file out of the temp folder, restarted gateway and it ran. Not working this time
“”“INFO [ModuleHook ] [15:15:48,430]: JNI Library: C:\Windows\TEMP\jniwrap-3.8.38051489701252876777.Build.3.8.31017514210\jniwrap64.dll
INFO | jvm 1 | 2021/02/15 15:15:48 | ERROR [SRContext ] [15:15:48,569]: Error during context startup.
INFO | jvm 1 | 2021/02/15 15:15:48 | java.lang.ExceptionInInitializerError
INFO | jvm 1 | 2021/02/15 15:15:48 | at com.jniwrapper.win32.system.Kernel32.isUnicode(Kernel32.java:77)
INFO | jvm 1 | 2021/02/15 15:15:48 | at com.jniwrapper.win32.FunctionName.(FunctionName.java:24)
INFO | jvm 1 | 2021/02/15 15:15:48 | at com.jniwrapper.win32.MessageLoopThread.(MessageLoopThread.java:24)
INFO | jvm 1 | 2021/02/15 15:15:48 | at com.inductiveautomation.opccom.ModuleHook.setup(ModuleHook.java:176)
INFO | jvm 1 | 2021/02/15 15:15:48 | at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.setup(ModuleManagerImpl.java:2187)
INFO | jvm 1 | 2021/02/15 15:15:48 | at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.setup(ModuleManagerImpl.java:263)
INFO | jvm 1 | 2021/02/15 15:15:48 | at com.inductiveautomation.ignition.gateway.SRContext.startupInternal(SRContext.java:1185)
INFO | jvm 1 | 2021/02/15 15:15:48 | at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:191)
INFO | jvm 1 | 2021/02/15 15:15:48 | at com.inductiveautomation.ignition.gateway.SRContext.asyncInit(SRContext.java:932)
INFO | jvm 1 | 2021/02/15 15:15:48 | at com.inductiveautomation.ignition.gateway.SRContext.access$200(SRContext.java:255)
INFO | jvm 1 | 2021/02/15 15:15:48 | at com.inductiveautomation.ignition.gateway.SRContext$2.run(SRContext.java:666)
INFO | jvm 1 | 2021/02/15 15:15:48 | at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:537)
INFO | jvm 1 | 2021/02/15 15:15:48 | at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 1 | 2021/02/15 15:15:48 | at java.util.concurrent.FutureTask.run(Unknown Source)
INFO | jvm 1 | 2021/02/15 15:15:48 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
INFO | jvm 1 | 2021/02/15 15:15:48 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO | jvm 1 | 2021/02/15 15:15:48 | at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 1 | 2021/02/15 15:15:48 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2021/02/15 15:15:48 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2021/02/15 15:15:48 | Caused by: com.jniwrapper.JNIWrapperException: java.io.IOException: Access is denied
INFO | jvm 1 | 2021/02/15 15:15:48 | Caused by: java.io.IOException: Access is denied
INFO | jvm 1 | 2021/02/15 15:15:48 | INFO [SRContext ] [15:15:48,573]: Ignition[”/main", state=STARTING] ContextState = FAULTED"""
Java version is 1.8.0_60-b27…this gateway has been running for years with no problems, other than the occasional glitch with the jni file issue. Anything I’m missing, kinda been staring at the trees for a bit on this and maybe I’m missing something.
