Ignition Gateway crashed
Ignition crashed with the following errors
Version: 8.1.35
Using Perspective
Can someone tell me what could be the reason for this failure?
I'm reading real-time data from an external server using Http Rest calls and suddenly that stopped working and server got frozen.
I had to restart the server to get it going again.
Not with just a screen shot. Please find your wrapper.log file in your install folder and grab the lines from about ten minutes before the crash to just after the restart. If very large, save to a separate file and upload separately. If not to large, paste into a comment using the "Preformatted text" button to keep it neat.
In the future, also screenshot the "Performance" page on the gateway, that shows the CPU and memory utilization at that time.
wrapper.log (2.9 MB)
Here is the wrapper.log file.
Ignition gateway failed on 20 April 11:09 PM
How can we go back in time and check the utilization details? historical performance data saved somewhere?
You can't, unless you've set up historization of the [System] tags that have that information.
Which is why I said "In the future".
Meanwhile, if you had click the "plus" icon on those "unexpected exception" log entries, you would have seen these details:
INFO   | jvm 4    | 2024/04/21 00:10:31 | W [c.i.i.g.p.ProjectFileWatcher  ] [05:10:31]: A ChangeListener in ProjectFileWatcher threw an unexpected exception.
INFO   | jvm 4    | 2024/04/21 00:10:31 | java.lang.OutOfMemoryError: Unable to allocate 11372904 bytes
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/jdk.internal.misc.Unsafe.allocateMemory(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/java.nio.DirectByteBuffer.<init>(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/java.nio.ByteBuffer.allocateDirect(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/sun.nio.ch.Util.getTemporaryDirectBuffer(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/sun.nio.ch.IOUtil.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/sun.nio.ch.FileChannelImpl.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/sun.nio.ch.ChannelInputStream.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/java.nio.file.Files.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/java.nio.file.Files.readAllBytes(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.toResource(ProjectFileTree.java:226)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.collectResources(ProjectFileTree.java:193)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.collectResources(ProjectFileTree.java:185)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.getProjectResources(ProjectFileTree.java:139)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at com.inductiveautomation.ignition.gateway.project.BaseProjectManager.updateProjectFileTree(BaseProjectManager.java:849)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileWatcher.lambda$scanProjectsDir$1(ProjectFileWatcher.java:121)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/java.util.concurrent.CopyOnWriteArrayList.forEach(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileWatcher.scanProjectsDir(ProjectFileWatcher.java:119)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:10:31 | 	at java.base/java.lang.Thread.run(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | W [c.i.i.g.p.ProjectFileWatcher  ] [05:15:32]: A ChangeListener in ProjectFileWatcher threw an unexpected exception.
INFO   | jvm 4    | 2024/04/21 00:15:32 | java.lang.OutOfMemoryError: Unable to allocate 11372904 bytes
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/jdk.internal.misc.Unsafe.allocateMemory(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/java.nio.DirectByteBuffer.<init>(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/java.nio.ByteBuffer.allocateDirect(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/sun.nio.ch.Util.getTemporaryDirectBuffer(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/sun.nio.ch.IOUtil.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/sun.nio.ch.FileChannelImpl.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/sun.nio.ch.ChannelInputStream.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/java.nio.file.Files.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/java.nio.file.Files.readAllBytes(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.toResource(ProjectFileTree.java:226)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.collectResources(ProjectFileTree.java:193)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.collectResources(ProjectFileTree.java:185)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.getProjectResources(ProjectFileTree.java:139)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at com.inductiveautomation.ignition.gateway.project.BaseProjectManager.updateProjectFileTree(BaseProjectManager.java:849)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileWatcher.lambda$scanProjectsDir$1(ProjectFileWatcher.java:121)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/java.util.concurrent.CopyOnWriteArrayList.forEach(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileWatcher.scanProjectsDir(ProjectFileWatcher.java:119)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:15:32 | 	at java.base/java.lang.Thread.run(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | W [c.i.i.g.p.ProjectFileWatcher  ] [05:20:32]: A ChangeListener in ProjectFileWatcher threw an unexpected exception.
INFO   | jvm 4    | 2024/04/21 00:20:32 | java.lang.OutOfMemoryError: Unable to allocate 11372904 bytes
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/jdk.internal.misc.Unsafe.allocateMemory(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/java.nio.DirectByteBuffer.<init>(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/java.nio.ByteBuffer.allocateDirect(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/sun.nio.ch.Util.getTemporaryDirectBuffer(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/sun.nio.ch.IOUtil.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/sun.nio.ch.FileChannelImpl.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/sun.nio.ch.ChannelInputStream.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/java.nio.file.Files.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/java.nio.file.Files.readAllBytes(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.toResource(ProjectFileTree.java:226)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.collectResources(ProjectFileTree.java:193)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.collectResources(ProjectFileTree.java:185)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.getProjectResources(ProjectFileTree.java:139)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at com.inductiveautomation.ignition.gateway.project.BaseProjectManager.updateProjectFileTree(BaseProjectManager.java:849)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileWatcher.lambda$scanProjectsDir$1(ProjectFileWatcher.java:121)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/java.util.concurrent.CopyOnWriteArrayList.forEach(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileWatcher.scanProjectsDir(ProjectFileWatcher.java:119)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:20:32 | 	at java.base/java.lang.Thread.run(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | W [c.i.i.g.p.ProjectFileWatcher  ] [05:25:32]: A ChangeListener in ProjectFileWatcher threw an unexpected exception.
INFO   | jvm 4    | 2024/04/21 00:25:32 | java.lang.OutOfMemoryError: Unable to allocate 11372904 bytes
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/jdk.internal.misc.Unsafe.allocateMemory(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/java.nio.DirectByteBuffer.<init>(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/java.nio.ByteBuffer.allocateDirect(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/sun.nio.ch.Util.getTemporaryDirectBuffer(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/sun.nio.ch.IOUtil.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/sun.nio.ch.FileChannelImpl.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/sun.nio.ch.ChannelInputStream.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/java.nio.file.Files.read(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/java.nio.file.Files.readAllBytes(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.toResource(ProjectFileTree.java:226)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.collectResources(ProjectFileTree.java:193)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.collectResources(ProjectFileTree.java:185)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.getProjectResources(ProjectFileTree.java:139)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at com.inductiveautomation.ignition.gateway.project.BaseProjectManager.updateProjectFileTree(BaseProjectManager.java:849)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileWatcher.lambda$scanProjectsDir$1(ProjectFileWatcher.java:121)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/java.util.concurrent.CopyOnWriteArrayList.forEach(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at com.inductiveautomation.ignition.gateway.project.ProjectFileWatcher.scanProjectsDir(ProjectFileWatcher.java:119)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO   | jvm 4    | 2024/04/21 00:25:32 | 	at java.base/java.lang.Thread.run(Unknown Source)
You gateway ran out of heap memory. Whatever you are doing with that external API likely needs more memory.
Or some Perspective user tried to graph a large time range at precisely the same time that the API calls were attempted.
Anyways, your gateway needs more ram allowed (in ignition.conf), which may mean the physical machine needs more ram.
This is interesting because it means one of his project resources is 11MB... I wonder what it is and how many others like it exist.
Thank you for the reply.
I've it set to max heap size 4GB
encoding=UTF-8
# Configuration files must begin with a line specifying the encoding
#  of the the file.
# Wrapper License Properties (Ignored by Community Edition)
# Professional and Standard Editions of the Wrapper require a valid
#  License Key to start.  Licenses can be purchased or a trial license
#  requested on the following pages:
# http://wrapper.tanukisoftware.com/purchase
# http://wrapper.tanukisoftware.com/trial
# Include file problems can be debugged by removing the first '#'
#  from the following line:
##include.debug
# The Wrapper will look for either of the following optional files for a
#  valid License Key.  License Key properties can optionally be included
#  directly in this configuration file.
#include ./wrapper-license.conf
# The following property will output information about which License Key(s)
#  are being found, and can aid in resolving any licensing problems.
#wrapper.license.debug=TRUE
# Wrapper Localization
# Specify the locale which the Wrapper should use.  By default the system
#  locale is used.
#wrapper.lang=en_US # en_US or ja_JP
# Specify the location of the Wrapper's language resources.  If these are
#  missing, the Wrapper will default to the en_US locale.
wrapper.lang.folder=../lang
# Wrapper Java Properties
# Java Application
#  Locate the java binary on the system PATH:
#  Specify a specific java binary:
set.JAVA_HOME=lib/runtime/jre-win
wrapper.java.command=%JAVA_HOME%/bin/java
# Tell the Wrapper to log the full generated Java command line.
#wrapper.java.command.loglevel=INFO
# Java Main class.  This class must implement the WrapperListener interface
#  or guarantee that the WrapperManager class is initialized.  Helper
#  classes are provided to do this for you.  See the Integration section
#  of the documentation for details.
wrapper.java.mainclass=org.tanukisoftware.wrapper.WrapperSimpleApp
# Java Classpath (include wrapper.jar)  Add class path elements as
#  needed starting from 1
wrapper.java.classpath.1=lib/wrapper.jar
wrapper.java.classpath.2=lib/core/common/*
wrapper.java.classpath.3=lib/core/gateway/*
# Java Library Path (location of Wrapper.DLL or libwrapper.so)
wrapper.java.library.path.1=lib
wrapper.java.library.path.2=lib/core/gateway
# Java Bits.  On applicable platforms, tells the JVM to run in 32 or 64-bit mode.
#wrapper.java.additional.auto_bits=TRUE
wrapper.java.additional.auto_bits.macosx=FALSE
# Java Additional Parameters
wrapper.java.additional.1=-Ddata.dir=data
#wrapper.java.additional.2=-Xdebug
#wrapper.java.additional.3=-Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=*:8000
# Initial Java Heap Size (in MB)
wrapper.java.initmemory=2048
# Maximum Java Heap Size (in MB)
wrapper.java.maxmemory=4096
# Application parameters.  Add parameters as needed starting from 1
wrapper.app.parameter.1=com.inductiveautomation.catapult.Catapult
wrapper.java.additional.7=-Dignition.allowunsignedmodules=true
wrapper.java.additional.8=-Dedition=
wrapper.java.additional.9=--add-opens=java.base/java.lang=ALL-UNNAMED
wrapper.java.additional.10=--add-opens=java.base/java.security.cert=ALL-UNNAMED
wrapper.java.additional.11=--add-opens=java.base/java.util=ALL-UNNAMED
wrapper.java.additional.12=--add-opens=java.base/jdk.internal.misc=ALL-UNNAMED
wrapper.java.additional.13=--add-opens=java.base/java.io=ALL-UNNAMED
wrapper.shutdown.timeout=120
wrapper.jvm_exit.timeout=120
# Set this value to TRUE to allow ignition.conf to be reloaded when the JVM is restarted
wrapper.restart.reload_configuration=TRUE
# Wrapper Logging Properties
# Enables Debug output from the Wrapper.
# wrapper.debug=TRUE
# Format of output for the console.  (See docs for formats)
wrapper.console.format=PM
# Log Level for console output.  (See docs for log levels)
wrapper.console.loglevel=INFO
# Log file to use for wrapper output logging.
wrapper.logfile=logs/wrapper.log
# Format of output for the log file.  (See docs for formats)
wrapper.logfile.format=LPTM
# Log Level for log file output.  (See docs for log levels)
wrapper.logfile.loglevel=INFO
# Maximum size that the log file will be allowed to grow to before
#  the log is rolled. Size is specified in bytes.  The default value
#  of 0, disables log rolling.  May abbreviate with the 'k' (kb) or
#  'm' (mb) suffix.  For example: 10m = 10 megabytes.
wrapper.logfile.maxsize=10m
# Maximum number of rolled log files which will be allowed before old
#  files are deleted.  The default value of 0 implies no limit.
wrapper.logfile.maxfiles=5
# Log Level for sys/event log output.  (See docs for log levels)
wrapper.syslog.loglevel=NONE
# Wrapper General Properties
# Allow for the use of non-contiguous numbered properties
wrapper.ignore_sequence_gaps=TRUE
# Title to use when running as a console
wrapper.console.title=Ignition Gateway
# Wrapper JVM Checks
# Detect DeadLocked Threads in the JVM. (Requires Standard Edition)
#wrapper.check.deadlock=TRUE
#wrapper.check.deadlock.interval=60
#wrapper.check.deadlock.action=RESTART
#wrapper.check.deadlock.output=FULL
# Out Of Memory detection.
#wrapper.filter.trigger.1000=java.lang.OutOfMemoryError
#wrapper.filter.action.1000=RESTART
#wrapper.filter.message.1000=The JVM has run out of memory.
wrapper.on_exit.default=SHUTDOWN
wrapper.on_exit.2=RESTART
# Wrapper Email Notifications. (Requires Professional Edition)
# Common Event Email settings.
#wrapper.event.default.email.debug=TRUE
#wrapper.event.default.email.smtp.host=<SMTP_Host>
#wrapper.event.default.email.smtp.port=25
#wrapper.event.default.email.subject=[%WRAPPER_HOSTNAME%:%WRAPPER_NAME%:%WRAPPER_EVENT_NAME%] Event Notification
#wrapper.event.default.email.sender=<Sender email>
#wrapper.event.default.email.recipient=<Recipient email>
# Configure the log attached to event emails.
#wrapper.event.default.email.attach_log=TRUE
#wrapper.event.default.email.maillog.lines=50
#wrapper.event.default.email.maillog.format=LPTM
#wrapper.event.default.email.maillog.loglevel=INFO
# Enable specific event emails.
#wrapper.event.wrapper_start.email=TRUE
#wrapper.event.jvm_prelaunch.email=TRUE
#wrapper.event.jvm_start.email=TRUE
#wrapper.event.jvm_started.email=TRUE
#wrapper.event.jvm_deadlock.email=TRUE
#wrapper.event.jvm_stop.email=TRUE
#wrapper.event.jvm_stopped.email=TRUE
#wrapper.event.jvm_restart.email=TRUE
#wrapper.event.jvm_failed_invocation.email=TRUE
#wrapper.event.jvm_max_failed_invocations.email=TRUE
#wrapper.event.jvm_kill.email=TRUE
#wrapper.event.jvm_killed.email=TRUE
#wrapper.event.jvm_unexpected_exit.email=TRUE
#wrapper.event.wrapper_stop.email=TRUE
# Specify custom mail content
wrapper.event.jvm_restart.email.body=The JVM was restarted.\n\nPlease check on its status.\n
# Wrapper Windows NT/2000/XP Service Properties
# WARNING - Do not modify any of these properties when an application
#  using this configuration file has been installed as a service.
#  Please uninstall the service before modifying this section.  The
#  service can then be reinstalled.
# Name of the service
wrapper.name=Ignition
# Display name of the service
wrapper.displayname=Ignition
# Description of the service
wrapper.description=Ignition Gateway
# Service dependencies.  Add dependencies as needed starting from 1
wrapper.ntservice.dependency.1=
# Mode in which the service is installed.  AUTO_START, DELAY_START or DEMAND_START
wrapper.ntservice.starttype=AUTO_START
# Allow the service to interact with the desktop.
wrapper.ntservice.interactive=false
#VERSION - DO NOT MODIFY: 15
Is there a quick way to identify them like the long db queries. ?
Set your init memory to the same value that way java claims it all at the beginning.
Best thing you can do for a scripts etc... is to use the Java nanotime and log custom script execution time. Or log when it goes above a certain length of time.
Also be careful where you are calling the api calls. Some areas are more tolerant to long running scripts than others.
Hmm, I don't think there's anything in Ignition to find large resources.
If your Gateway is running on Linux you could change into the projects directory and run something like du -h * | sort -h and look at the larger entries.
edit: probably needs a little tweaking to find the large resources and not just the large projects.
any of these windows actions do affect the Ignition service?
