Ignition Gateway Database Connection
I noticed that there is a folder in the database folder within the system tag folder (see screenshot). I cannot delete this empty folder. there is no database connection with this name. could you please advise?
note: want to delete since it appears in the diagnostic dashboard
What version are you currently running?
Ignition Gateway 8.1.20
This is a bug that was supposed to be fixed in 8.1.3. Do you know if the connections were deleted prior to upgrading to 8.1.3 or later?
If so, you could try creating a new database connection with the same name and then delete it again. That might clear up the system tags.
Thanks for asking, I created a connection and then deleted it. now I have same but it is not empty now:
It would probably be best to open a support ticket to dig into the issue further.
https://support.inductiveautomation.com/hc/en-us
