Ignition gateway down
Hello I had a problem in Ignition, the gateway was down arround 20 minutes, I was checking the logs into Ignition and windows logs/application and I did not find the problem. Do you know where can I get more information about the gateway was down? After 20 minutes the gateway is running. The server was not reseted, so I think the problem maybe was just in the service.
I appreciated if you can guide me to get more information.
Thank you.
Get a copy of the wrapper.log text file from the server's filesystem (in the Ignition install folder) and attach that to a support ticket.
I see, thank you.
