Downloaded ignition 7.9.12 and restored a 7.9.10 gateway. Control utility says gateway is faulted and won’t start
Attached is the wrapper log
wrapper.log (1.6 MB)Thanks!
The logs you’ve attached are dated January and show Ignition 7.9.10 starting. Are you sure you’ve grabbed the right ones?
Can you check which version of Java you have installed as well?
IgnitionHMI_thread_dump_20190727-182951.txt (39.8 KB)
I first installed 7.9.10 back in january most likely
