Ignition Gateway Logs are being flooded with following message(s)
Good morning,
I am working with a customer and their gateway logs are being flooded with the following message(s). They are running version 8.1.35.
|INFO   | jvm 1    | 2024/09/05 15:44:53 | |at com.inductiveautomation.ignition.gateway.tags.runtime.nodes.BasicTagDefinition.shouldBeEnabled(BasicTagDefinition.java:363)|
|INFO   | jvm 1    | 2024/09/05 15:44:53 | |at com.inductiveautomation.ignition.gateway.tags.runtime.nodes.FolderNode.shouldBeEnabled(FolderNode.java:482)|
  1. How do I stop the flooding of messages?
  2. How do I identify and fix the root issue?
  3. Is there a version where the issue is fixed?
Existing topics suggest rebooting the gateway should help but I'd like to be certain that is the case before suggesting that to the customer.
It looks like the root logger may be called *.batchoperations, so if you can find that and set the level to OFF it might stop the log spam.
I found a ticket that looks like it might be this and it indicates it's fixed for 8.3 but not in 8.1.x. It seems the root cause is a lack of validation preventing a user from drag and dropping a folder onto itself.
I did have the 2 items listed under *.batchoperations turned off but it didn't stop the spam. If I turn the 2 items listed under *.batchoperations off and then restart the gateway should that be sufficient to fix the issue or do I also need to delete any log files?
Just restarting the gateway should be enough if this is the same issue. Changes to loggers made in the gateway UI do not persist across restarts, but it shouldn't matter.
I will pass on the details to the customer and update this topic later.
