Hi all,
While loading Gateway page it shows blank page in UI.
Can someone help to fix this issue
Thanks in advance
/VR
You'll have to look in the install directory to retrieve the wrapper.log file, and study the errors near the end for clues. Or share with us to help you look at it. Or open a support ticket if the exposure would be a problem.
Please share more information as pturmel mentioned or provide clarification on the below so is easier to isolate the issue accurately:
Was this screenshot taken from the server/PC hosting the gateway?
Is the service confirmed to be running?
Was the service configured to use port 8088?
Have there been any recent cybersecurity or firewall changes on the computer hosting the service?
Was the system previously operational, or are you currently commissioning the gateway?
Is the gateway and projects running but gateway web service inaccessible, or is the entire service stopped?
Also check that javascript is enabled in your browser.
Was this screenshot taken from the server/PC hosting the gateway? - It is taken from the server directly
Is the service confirmed to be running? - Yes Ignition windows service running
Was the service configured to use port 8088? - Yes
Have there been any recent cybersecurity or firewall changes on the computer hosting the service? - No
Was the system previously operational, or are you currently commissioning the gateway? - This was working gateway it is happening randomly.
Is the gateway and projects running but gateway web service inaccessible, or is the entire service stopped? Could you please guide me how to check on this
This was working previously. It is happening randomly
INFO | jvm 1 | 2026/02/15 11:05:45 | W [o.e.j.s.HttpChannel ] [11:05:45.064]: handleException / org.eclipse.jetty.http.BadMessageException: 400: No Host
INFO | jvm 1 | 2026/02/15 11:05:46 | W [o.a.w.c.u.l.WicketObjects ] [11:05:46.222]: Could not resolve class [com.inductiveautomation.factorypmi.gateway.web.ClientLauncherDownloadPage]
INFO | jvm 1 | 2026/02/15 11:05:46 | java.lang.ClassNotFoundException: com.inductiveautomation.factorypmi.gateway.web.ClientLauncherDownloadPage
INFO | jvm 1 | 2026/02/15 11:05:46 | at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(Unknown Source)
INFO | jvm 1 | 2026/02/15 11:05:46 | at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(Unknown Source)
INFO | jvm 1 | 2026/02/15 11:05:46 | at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:460)
INFO | jvm 1 | 2026/02/15 11:05:46 | at java.base/java.lang.Class.forName0(Native Method)
INFO | jvm 1 | 2026/02/15 11:05:46 | at java.base/java.lang.Class.forName(Unknown Source)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.application.AbstractClassResolver.resolveClass(AbstractClassResolver.java:108)
INFO | jvm 1 | 2026/02/15 11:05:46 | at com.inductiveautomation.ignition.gateway.web.IgnitionWebAppImpl$GatewayClassResolver.resolveClass(IgnitionWebAppImpl.java:183)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.core.util.lang.WicketObjects.resolveClass(WicketObjects.java:72)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.util.reference.ClassReference.get(ClassReference.java:59)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.util.reference.ClassReference.get(ClassReference.java:33)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.core.request.mapper.MountedMapper.getPageClass(MountedMapper.java:553)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.core.request.mapper.MountedMapper.checkPageClass(MountedMapper.java:548)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.core.request.mapper.AbstractBookmarkableMapper.mapHandler(AbstractBookmarkableMapper.java:389)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.core.request.mapper.MountedMapper.mapHandler(MountedMapper.java:395)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.request.mapper.CompoundRequestMapper.mapHandler(CompoundRequestMapper.java:215)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.request.cycle.RequestCycle.mapUrlFor(RequestCycle.java:429)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:201)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:175)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:890)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:261)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:218)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:289)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:259)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:201)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:282)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:210)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1635)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:598)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1580)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1553)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
INFO | jvm 1 | 2026/02/15 11:05:46 | at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.Server.handle(Server.java:563)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.HttpChannel$RequestDispatchable.dispatch(HttpChannel.java:1598)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:753)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:501)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:287)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:558)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:379)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:146)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:421)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:390)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:277)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.run(AdaptiveExecutionStrategy.java:199)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
INFO | jvm 1 | 2026/02/15 11:05:46 | at java.base/java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2026/02/15 11:05:46 | Suppressed: java.lang.ClassNotFoundException: com.inductiveautomation.factorypmi.gateway.web.ClientLauncherDownloadPage
INFO | jvm 1 | 2026/02/15 11:05:46 | at java.base/java.net.URLClassLoader.findClass(Unknown Source)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.webapp.WebAppClassLoader.findClass(WebAppClassLoader.java:581)
INFO | jvm 1 | 2026/02/15 11:05:46 | at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:484)
INFO | jvm 1 | 2026/02/15 11:05:46 | ... 68 common frames omitted
INFO | jvm 1 | 2026/02/15 11:05:46 | E [o.a.w.DefaultExceptionMapper ] [11:05:46.222]: Unexpected error occurred
This is the error message I got from wrapper.log
I think this is a known issue. I presume you do not have Vision installed? Or perhaps it is faulted?
Look for more log entries with 'factorypmi' in them for clues. (Or, open a support ticket.)
FYI I received this same error, it occurred after uninstalling the Vision module on a system running Ignition 8.1.53. I uninstalled Vision because it was just running in trial mode.
Support advised me to restart the Ignition service (which brought back the gateway page), and re-install the vision module.
