Hi All,
We have an ignition server running at version 8.0.16. We are trying to make a redundant setup. Both primary and secondary will have 4 network interface. The clients connected to the primary at the moment uses a mix of all the interfaces.
When the backup node becomes online and using network interface 1 as the interface for gateway connections, all clients which are previously using network interface 1 lost connection to gateway.
Question:
- Does ignition gateway makes the gateway connection a dedicated network for redundancy communication only?
