If you look at the picture file I attached
In the upper left corner, it says CoreCertificationTest.
I want to restore this to Ignition-jgkim-pc.
How can I restore it?
After logging in with another account from the ignition url, it was changed like that, so the account I used previously could not log in.
If this is still for the purposes of the test, you cannot receive ANY help from this forum. only training@inductiveautomation.com
If I understand you correctly, you restored the Core cert gateway backup while you had your original gateway running. This restored the user source in the core cert backup and replaced your original user source. Now you want to restore your previous gateway backup? If that's the case, then it's not a certification question and is valid to ask on this forum.
If you didn't backup your original gateway though, then you have only limited options.
It might seem a stupid question, but are you connecting to the same gateway address?
You should have taken the backup of your previous gateway before restoring core test gateway.
Yes I have connected to the same gateway.
When I restore the file received through system backup of a project created in another account to the gateway I am using, it seems that the previously used file is completely gone and opened as the received file.
In this case, is it not possible to restore it before?
Caution: When you perform a Gateway Restore, ALL of the server's current configuration will be permanently lost! Restoring a Gateway backup overwrites all of the existing settings including your projects. There is no merge option for a Gateway backup. We recommend you always make a backup of the existing server immediately before performing a Gateway Restore.
Gateway Backup and Restore - Ignition User Manual 8.1 - Ignition Documentation (inductiveautomation.com)
You can configure automatic backups, for the future:
Gateway Settings - Ignition User Manual 8.1 - Ignition Documentation (inductiveautomation.com)
Thank you for letting me know
I've the same issue how did you resolved this ?
