We’re running 7.7.2 on a Windows 64 bit server. We have around 250 clients running at any given time. We occasionally (like today) are seeing the Gateway become unresponsive, with some clients getting a “gateway timeout” message.
Restarting the gateway solves the problem. When looking through the wrapper log files, the only anomaly that we see is a set of messages related to the timeout issue (see below). This message set repeated every 15 minutes or so in the logs prior to us restarting.
Would anyone have any thoughts on things we can check to zero in on the cause? We’d like to get a better handle on the issue aside from doing planned restarts to prevent the problem.
Thanks in advance.
INFO | jvm 1 | 2016/05/04 07:36:57 | java.io.IOException: java.util.concurrent.TimeoutException: Idle timeout expired: 30001/30000 ms
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.util.BlockingCallback.block(BlockingCallback.java:101)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.HttpInputOverHTTP.blockForContent(HttpInputOverHTTP.java:62)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.HttpInput$1.waitForContent(HttpInput.java:392)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.HttpInput.read(HttpInput.java:161)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.HttpInput.read(HttpInput.java:125)
INFO | jvm 1 | 2016/05/04 07:36:57 | at com.sun.org.apache.xerces.internal.impl.XMLEntityManager$RewindableInputStream.read(Unknown Source)
INFO | jvm 1 | 2016/05/04 07:36:57 | at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.setupCurrentEntity(Unknown Source)
INFO | jvm 1 | 2016/05/04 07:36:57 | at com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.determineDocVersion(Unknown Source)
INFO | jvm 1 | 2016/05/04 07:36:57 | at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
INFO | jvm 1 | 2016/05/04 07:36:57 | at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
INFO | jvm 1 | 2016/05/04 07:36:57 | at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
INFO | jvm 1 | 2016/05/04 07:36:57 | at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
INFO | jvm 1 | 2016/05/04 07:36:57 | at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:229)
INFO | jvm 1 | 2016/05/04 07:36:57 | at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
INFO | jvm 1 | 2016/05/04 07:36:57 | at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
INFO | jvm 1 | 2016/05/04 07:36:57 | at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:696)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:526)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:568)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:221)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1110)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:453)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:183)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1044)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.Server.handle(Server.java:459)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:280)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:229)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.io.AbstractConnection$1.run(AbstractConnection.java:505)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:607)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:536)
INFO | jvm 1 | 2016/05/04 07:36:57 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2016/05/04 07:36:57 | Caused by:
INFO | jvm 1 | 2016/05/04 07:36:57 | java.util.concurrent.TimeoutException: Idle timeout expired: 30001/30000 ms
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.io.IdleTimeout.checkIdleTimeout(IdleTimeout.java:153)
INFO | jvm 1 | 2016/05/04 07:36:57 | at org.eclipse.jetty.io.IdleTimeout$1.run(IdleTimeout.java:50)
INFO | jvm 1 | 2016/05/04 07:36:57 | at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 1 | 2016/05/04 07:36:57 | at java.util.concurrent.FutureTask.run(Unknown Source)
INFO | jvm 1 | 2016/05/04 07:36:57 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
INFO | jvm 1 | 2016/05/04 07:36:57 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO | jvm 1 | 2016/05/04 07:36:57 | at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 1 | 2016/05/04 07:36:57 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
