Ignition gateway was crashed/restarted but when I checked the services on Linux server, it was showing up since last 2 months 24 days.
Ignition version: 8.0.13 Hosted on RHEL 7
[USER@MYSERVER savedi]# systemctl status Ignition-Gateway.service
● Ignition-Gateway.service - Ignition-Gateway
Loaded: loaded (/etc/systemd/system/Ignition-Gateway.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2023-11-13 07:26:17 EST; 2 months 24 days ago
Process: 1027 ExecStart=/apps/local/bin/ignition/ignition.sh start sysd (code=exited, status=0/SUCCESS)
Main PID: 1245 (ignition-gatewa)
CGroup: /system.slice/Ignition-Gateway.service
├─1245 /apps/local/bin/ignition/./ignition-gateway /apps/local/bin/ignition/data/ignition.conf wrapper.syslog.ident=Ignition-Gateway wrapper.pi...
└─5204 /apps/local/bin/ignition/lib/runtime/jre-nix/bin/java -Ddata.dir=/apps/local/bin/ignition/data -Xms1024m -Xmx8192m -Djava.library.path=/...
Gateway | CLIENT_Linux
Version: 8.0.13 (b2020060815)
License: partial
Uptime: a day
Errors in log file -
NFO | jvm 3 | 2024/02/05 16:55:57 | I [p.ClientSession ] [21:55:57]: Socket connected to session. pageId=24739de3 session-project=DanaOEE
INFO | jvm 3 | 2024/02/05 16:57:57 | #
INFO | jvm 3 | 2024/02/05 16:57:57 | # A fatal error has been detected by the Java Runtime Environment:
INFO | jvm 3 | 2024/02/05 16:57:57 | # SIGSEGV (0xb) at pc=0x00007fb61140520c, pid=29567, tid=29579
INFO | jvm 3 | 2024/02/05 16:57:57 | # JRE version: OpenJDK Runtime Environment (Zulu11.37+18-SA) (11.0.6+10) (build 11.0.6+10-LTS)
INFO | jvm 3 | 2024/02/05 16:57:57 | # Java VM: OpenJDK 64-Bit Server VM (11.0.6+10-LTS, mixed mode, tiered, compressed oops, g1 gc, linux-amd64)
INFO | jvm 3 | 2024/02/05 16:57:57 | # Problematic frame:
INFO | jvm 3 | 2024/02/05 16:57:57 | # V [libjvm.so+0xbe820c] compute_tree_cost(SwitchRange*, SwitchRange*, float)+0x21c
INFO | jvm 3 | 2024/02/05 16:57:57 | # No core dump will be written. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
INFO | jvm 3 | 2024/02/05 16:57:57 | # An error report file with more information is saved as:
INFO | jvm 3 | 2024/02/05 16:57:57 | # /apps/local/bin/ignition/hs_err_pid29567.log
INFO | jvm 3 | 2024/02/05 16:57:57 | # Compiler replay data is saved as:
INFO | jvm 3 | 2024/02/05 16:57:57 | # /apps/local/bin/ignition/replay_pid29567.log
INFO | jvm 3 | 2024/02/05 16:57:57 | # If you would like to submit a bug report, please visit:
INFO | jvm 3 | 2024/02/05 16:57:57 | # Customer Support for Platform Core & Platform Prime | Azul
STATUS | wrapper | 2024/02/05 16:57:57 | JVM received a signal UNKNOWN (6).
STATUS | wrapper | 2024/02/05 16:57:57 | JVM process is gone.
ERROR | wrapper | 2024/02/05 16:57:57 | JVM exited unexpectedly.
STATUS | wrapper | 2024/02/05 16:58:01 | Reloading Wrapper configuration...
STATUS | wrapper | 2024/02/05 16:58:02 | JVM process is gone.
STATUS | wrapper | 2024/02/05 16:58:02 | Launching a JVM...
INFO | jvm 4 | 2024/02/05 16:58:02 | WrapperManager: Initializing...
Not sure what happened here
wrapper.log (4.5 MB)
