Ignition gateway web server settings
I have a Ignition gateway running in Azure, with a certificate, using https port 443. From my home office I can only reach the azure gateway via https.
Several times during working in the designer i have lost the connection to the server, and when i open the gateway from work office (http) I can see that the HTTPS port has changed back to default 8043 by itself. Is this a known issue?
First I've heard. You should open a support ticket. And survey your colleagues. /:
